Coolant leak/overheating?
103,000 MILES • V6 • AUTOMATIC
KELLIANNE
It’s leaking what I believe is coolant, I was driving car started shaking / sputtering and then overheated. Pulled over, coolant reservoir was empty, filled with water, tried to drive sputtering stopped but still overheating.
Mar 14, 2023 at 9:46 PM
MIKE H R
  • 3,094 POSTS
With the engine cool, remove the radiator cap, fill the radiator with water and some in the reservoir. start the engine with the radiator cap off. Let it run then put the cap back on and shut the car off. Let it sit and cool down. Sometimes the coolant can get vapor locked and not circulate. Check the reservoir to see if the water went down. If it fills up when cool the thermostat could be going bad. Be careful as the car and water can be very hot if it overheats.
Mar 15, 2023 at 2:07 AM
  • 110,248 POSTS
I noticed we haven't heard from you for a couple of days. Have you been able to make any progress? We are interested in knowing.
Let us know if you have other questions as well.
joe
Mar 17, 2023 at 4:17 PM
