Coolant leak/new radiator + new condenser
200,000 MILES • 5.3L • V8 • AUTOMATIC
AC408
  • 6 POSTS
I just replaced radiator and condenser, after my radiator sprung a crack on the passenger side, shooting coolant all over while on the freeway. Immediately after changing both radiator and condenser, I notice coolant leaking after starting car for first time since repairs. Then air system of interior stopped powering in but I only had to replace fuses. Now air blows but not how it should. Hot air never gets hot and cold air never gets “AC cold”. Now when I start car it stays at mid heat as long as I’m parked, but once I drive about two blocks it starts to overheat.
I originally thought maybe the leak was due to over filling system with coolant. Like tends to be dripping from front driver side radiator end.
Any input would be helpful.
Aug 31, 2021 at 5:11 PM
  • 110,248 POSTS
If there is still a leak in the cooling system, we need to determine what is causing it. Also, if you haven't already, make sure the coolant level is full.
A leak can be a radiator hose, heater hose, water pump, and so on. Since the radiator is new, we can assume that isn't the issue.
To start, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/car-is-leaking-coolant
If that doesn't help, we need to pressure test the system. This is done with the engine cold so you can move things around easily. Here is a link that shows how it's done:
https://www.2carpros.com/articles/radiator-pressure-test
Now, you will need a pressure tester, but most parts stores will lend one to you,
Let me know what you find or if you have other questions. Also, let me know if you notice the leak from the front of the engine compartment or rear.
Sep 1, 2021 at 1:45 PM
AC408
  • 6 POSTS
I will see about getting the tester done this weekend but I see it coming from front end. Dripping from the frame in an area that sit directly under the radiator and condenser. Mainly drips on driver side unless on unleveled pavement.
Sep 2, 2021 at 10:43 PM
AC408
  • 6 POSTS
And I can have it running for an hour in park and no overheating, but once I drive it it overheats before I make it half way around the block.
Sep 2, 2021 at 10:44 PM
AC408
  • 6 POSTS
Amen, I just replaced the temperature sensor but just the main piece not the wiring harness.
Sep 2, 2021 at 10:46 PM
  • 110,248 POSTS
Did the sensor take care of the issue?
Sep 3, 2021 at 2:16 PM
AC408
  • 6 POSTS
No, still having the same issue. I haven’t done pressure test yet going to try for sure by this weekend. I’m just currently on a budget and I’m having to do some maintenance things in my other Impala which I use daily for work.
Sep 4, 2021 at 5:46 AM
  • 110,248 POSTS
No problem whatsoever. When you get to it, let me know. I'm interested in knowing if it's fixed or if I can help.
Take care of yourself, and I look forward to hearing from you.
Sep 4, 2021 at 1:47 PM
