Coolant leak into engine
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ROBERT MILLER2
I have a small amount of coolant getting into my engine. I thought it was the radiator. I changed it out and I’m still getting a leak from somewhere? Any ideas on how it’s getting into engine?
Apr 26, 2022 at 12:58 AM
  • 110,248 POSTS
If the coolant is getting into the engine / mixing with engine oil, that is usually caused by a failed head gasket.
Do me a favor. Take a look through this link and let me know if it helps and what you find.
Let me know if you have additional questions.
Apr 26, 2022 at 7:14 AM
ROBERT MILLER2
I have been afraid that it might be a blown gasket? The only reason I believed it might be something else is became I can drive it 200 miles and it doesn’t run hot? It doe’s loose coolant but that’s all it?
Apr 26, 2022 at 11:36 PM
  • 110,248 POSTS
Is there any evidence of white smoke from the exhaust? Do any of the other symptoms listed in the aforementioned link mirror what you are seeing?
If you are losing coolant, the next thing I would suggest is to check engine compression to determine if there are one or more cylinders that are weak. Also, the spark plugs may have a grayish powdery appearance on the ground strap.
Here is a link that explains how to perform the compression test:
Let me know what you find.
Take care
Apr 27, 2022 at 11:25 AM
