blown head gasket?
1997 FORD F-150
178,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JAYDEE504
I had gotten a check engine light and the code came up a p0306 misfire in cylinder 6. I figured the spark plug went bad so I decided to change it out and when I took the boot off it was filled with coolant. I didn't see anything leaking from the top but I did notice some coolant dripping from underneath. Anyone have an idea what it could be?
Sep 2, 2020 at 11:57 AM
If you have coolant in the cylinder, then we need to go to the head gasket first. Here is a test that we need to run through:
Let's start here and go from there. Thanks
Sep 2, 2020 at 12:07 PM
