Coolant leak disappeared
72,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
BWHUOT63
  • 15 POSTS
For two days there was a coolant leak coming from passenger side bottom corner, I can see vapor coming from beneath the headlight and a little puddle. The overflow tank was near empty. The last two days it seems to have stopped leaking as I didn't see any vapor coming from the bottom of the headlight and the coolant level hasn't dropped. I didn't use any stop leak product.
Apr 8, 2020 at 7:46 PM
Good morning,
Coolant leaks cannot fix themselves.
https://www.2carpros.com/articles/car-is-leaking-coolant
Did you fill the tank back to level? The leak may have stopped from low coolant.
https://www.2carpros.com/articles/coolant-leak-symptoms
I would have the system pressure tested to determine the source of the leak. You can either rent a tester or have a parts store do it for you.
https://www.2carpros.com/articles/radiator-pressure-test
Once it is determined, let me know so I can further help you with the leak.
Apr 8, 2020 at 8:53 PM
BWHUOT63
  • 15 POSTS
Had it pressure tested, turned out to be the water pump and S outlet located on left side next to cylinder head.
Apr 17, 2020 at 12:48 PM
Okay, I attached the procedure for you to replace the water pump below.
https://www.2carpros.com/articles/water-pump-replacement
Let me know if you have any other questions.
Apr 17, 2020 at 9:57 PM
