Coolant leak but not from radiator
1996 OLDSMOBILE CUTLASS
JEWYINW
The car leaks coolant, but and there no sign of it coming from the radiator, and the leak is no where near the radiator, it looks to be coming from the opposite side the water pump is, just a little bit below one of the radiator hoses, the end that is closest to the engine, I'm not sure where this leak is coming from, everything has been tighten and checked multiple times, please help
Oct 5, 2013 at 4:19 AM
CARADIODOC
  • 34,367 POSTS
There's two ways that can help in finding the cause. The fastest is a simple pressure test. You can borrow the tool from an auto parts store that rents or borrows tools. With that you'll have to watch where the coolant is running down from.
You can also add a small bottle of dark purple dye to the coolant, then search later with a black light. You'll find that black light at auto parts stores too. The dye will show up as a bright yellow stain that you can follow back to the source. This method works really well with slow leaks when the coolant evaporates too quickly or when it makes a large area wet but you can't see it running from a specific place.
Oct 5, 2013 at 4:36 AM
JEWYINW
Thank you so much, I'm going to try these things right now
Oct 5, 2013 at 11:02 AM
