Coolant leak behind front passenger tire
126,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KCOOK
My temperature gauge will say my car is overheating when driving and the engine is not even hot, but when stopped it will go back down to normal or a little lower. I added coolant to the radiator and noticed that there was coolant leaking behind my passenger tire just could not find out from where exactly. Recently got it fixed for a blown hose under the throttle body.
Mar 17, 2018 at 3:29 AM
MIKE H R
  • 3,094 POSTS
would check the hoses, there may be a leak where you do no't see it. I believe that the reason it goes to hot is that there is not enough coolant in the engine and when you idle the coolant flows. Have a pressure test done on the coolant system. that should show where it is leaking. you say you had a leak fixed, just wonder if it could be from the same area.
Mar 17, 2018 at 6:14 AM
