Coolant leak at water outlet
72,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
MIKE WEAVER2
I have a leak at my water outlet that I am going to replace myself. I know that I will have to flush the coolant before I remove the unit, but I was wondering if there is a certain process to removing the unit? I could not find anything else on how to replace it.
Oct 17, 2016 at 11:14 PM
HMAC300
  • 48,601 POSTS
I assume this is the correct part(s) in pictures. make sure when filling to use 50/50 Dexcool and to open air bleed until fluid comes out when refilling.
Oct 18, 2016 at 5:13 AM
RICK SCHINDLER
Uh, he posted a picture showing you and said "water outlet" you assumed the lower radiator hose going to the water pump...
Hmm I always thought the water pump was the inlet...
Aug 22, 2020 at 4:17 PM
Good morning,
The flow of the coolant is into the water pump, through the engine and exits out the top to back into the radiator for cooling.
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/radiator-pressure-test
Was that the correct part he identified?
https://www.2carpros.com/articles/replace-radiator-hoses
Aug 22, 2020 at 9:42 PM
