What are the installation procedures for replacing Ford part # 1F1Z8N030BA
102,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DARKHORSEREDMANE
  • 6 POSTS
Coolant leak at "connector" which is mounted into lower intake manifold connected coolant reservoir return line to engine.
Jul 24, 2019 at 11:08 PM
Good morning,
Can you attach a picture of the connector you referred to in the post?
Jul 24, 2019 at 11:25 PM
DARKHORSEREDMANE
  • 6 POSTS
Here they are.
Jul 24, 2019 at 11:30 PM
That is an elbow for the heater hose off the intake. Is that correct? It looks like it presses into the manifold and has a hose on the other side.
Hard to see from a distance with the picture.
Jul 24, 2019 at 11:53 PM
DARKHORSEREDMANE
  • 6 POSTS
You are correct it is an elbow, but it is the return/overflow line from the coolant reservoir.
Jul 24, 2019 at 11:58 PM
Okay, what is the issue with the elbow? Is it leaking? Broken? That is a rare part to fail unless there is severe corrosion in the cooling system.
Jul 25, 2019 at 12:05 AM
DARKHORSEREDMANE
  • 6 POSTS
It is corroded with pin holes leaking coolant, I have remove the old part which was actually loose from the corrosion. New part has been ordered, I just want to make sure I install it properly.
Jul 25, 2019 at 12:08 AM
Okay, did you get all of it out of the manifold?
Like I said before, it presses into the intake manifold. When you get the new part, you will need to tap it into the manifold until it bottoms out.
I would also have the cooling system acid flushed to get rid of all the corrosion. Water pump impeller issues are common for systems with this corrosion.
Jul 25, 2019 at 12:11 AM
DARKHORSEREDMANE
  • 6 POSTS
Greatly appreciate your time and attention in responding. If I may ask one more question. Should any sealant or lubricant be applied before tapping the part in?
Jul 25, 2019 at 12:13 AM
No, that will make it difficult for installation and you may damage the connector. The most I would use is a little vaseline.
You are welcome.
Always glad to help.
Jul 25, 2019 at 12:21 AM
DARKHORSEREDMANE
  • 6 POSTS
Much appreciate, thank you!
Jul 25, 2019 at 12:25 AM
You are welcome.
Jul 25, 2019 at 12:28 AM
