Coolant leak
200,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
BRANDON MARTIN
  • 21 POSTS
I'm leaking coolant and missing a piece to a part and i dont know what it is.
Oct 19, 2019 at 1:10 AM
Good morning,
Can you post a couple more pictures for me to view? It looks like the filler neck but need to be sure.
Oct 19, 2019 at 1:18 AM
It looks like the filler neck for the radiator. I attached a picture for you.
It is part of the radiator itself. The entire radiator needs to be replaced.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
https://www.youtube.com/watch?v=7ZzTlXwe1UY
Oct 19, 2019 at 1:24 AM
BRANDON MARTIN
  • 21 POSTS
Well, my dad has the same kind his is the same way. he said a seal is missing.
Oct 19, 2019 at 1:28 AM
BRANDON MARTIN
  • 21 POSTS
Someone says rubber expansion plug.
Oct 19, 2019 at 1:35 AM
No, it is part of the filler neck for the radiator. It is not available for purchase. It is part of the radiator itself and the radiator has to be replaced.
Oct 19, 2019 at 1:37 AM
BRANDON MARTIN
  • 21 POSTS
Do you have another picture of it exactly?
Oct 19, 2019 at 1:42 AM
You have the picture you sent me.
What do you need to see?
Oct 19, 2019 at 1:44 AM
BRANDON MARTIN
  • 21 POSTS
No, I mean do you have a whole picture of the same radiator? and is the filler separate thing the actual radiator cap?
Oct 19, 2019 at 1:49 AM
The picture I attached shows it is part of the radiator. The piece that has failed is circled in the picture.
Oct 19, 2019 at 1:56 AM
BRANDON MARTIN
  • 21 POSTS
Okay, thank you. I had one more about my Rodeo 1999 Isuzu.
Oct 19, 2019 at 2:26 AM
Okay.
Oct 19, 2019 at 2:33 AM
BRANDON MARTIN
  • 21 POSTS
I have the instructions on removing the wheel bearing and installing it but it says something about caulking around the axle nut.
Oct 19, 2019 at 2:41 AM
BRANDON MARTIN
  • 21 POSTS
Do you know what there talking about?
Oct 19, 2019 at 3:13 AM
Again, you need to start a new question at the beginning.
One vehicle per question.
I know what you are talking about but will respond with your new question.
Oct 19, 2019 at 6:04 AM
BRANDON MARTIN
  • 21 POSTS
I started a new question.
Oct 19, 2019 at 6:08 AM
You cannot do it here on this question.
www.2carpros.com/question
Oct 19, 2019 at 6:12 AM
BRANDON MARTIN
  • 21 POSTS
No I mean I opened up a new question on my page about wheel bearing.
Oct 19, 2019 at 6:13 AM
Let me check.
Oct 19, 2019 at 6:17 AM
BRANDON MARTIN
  • 21 POSTS
Okay, thank you for your patience. I'm being frustrating and I do apologize.
Oct 19, 2019 at 6:21 AM
No worries, we are good.
Oct 19, 2019 at 6:28 AM
