Coolant leak
219,000 MILES • 4.0L • V8 • 4WD • AUTOMATIC
ALLIN
I am losing antifreeze out of my transmission and wanted to know what it was. thanks in advance. The coolant is coming from a stud with a nut on it the end of the stud is square.
Dec 25, 2019 at 12:16 AM
Good morning,
There should be no coolant in the transmission.
Do you mean it is dripping off the transmission? If you do, can you post a picture of the leak area for me?
Did you pressure test the cooling system?
https://www.2carpros.com/articles/radiator-pressure-test
Dec 25, 2019 at 12:59 AM
