Some days there is a small leak other days the reservoir is empty, but it never overheated and it's not mixing with the oil.
Aug 29, 2022 at 8:18 PM
✓Experienced Mechanic
This could be a leak in the water pump or radiator, but to be sure we need to do a pressure test and use a flashlight to see where the leak is coming from. Keep in mind the water pump will only leak when the engine is running. Start with the engine cold and remove the radiator cap, you can rent a pressure tester for free or cheap from an auto parts store.
