Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Engine Cooling
Leak
Engine coolant is leaking looks like it is coming from the water pump?
2006 DODGE RAM
119,686 MILES
BROOKE123
MEMBER
1 POST
Coolant was noted on the ground you see the truck. It looks like it is coming from the water pump. All gauges are reading normal.
Jul 22, 2019 at 3:51 AM
Experienced Mechanic
Good afternoon,
Did you pressure test the system to confirm?
https://www.2carpros.com/articles/radiator-pressure-test
It could be the water pump but is better to confirm than to guess.
https://www.2carpros.com/articles/water-pump-replacement
Jul 22, 2019 at 9:16 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
