Engine coolant is leaking looks like it is coming from the water pump?
2006 DODGE RAM
119,686 MILES
BROOKE123
Coolant was noted on the ground you see the truck. It looks like it is coming from the water pump. All gauges are reading normal.
Jul 22, 2019 at 10:51 AM
Good afternoon,
Did you pressure test the system to confirm?
https://www.2carpros.com/articles/radiator-pressure-test
It could be the water pump but is better to confirm than to guess.
https://www.2carpros.com/articles/water-pump-replacement
Jul 22, 2019 at 4:16 PM
