coolant leak
1997 HOLDEN COMMODORE
230,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
CLINT2184
can anyone help me???? i have a vt 1998 model and i have a strange coolant leak just above the trans its like a rubber grommet above the trans does anyone know how to fix this i have a few photos of where it is leaking please help
Apr 4, 2016 at 1:09 PM
  • 31,937 POSTS
IF this is coming from the trans tunnel and not the engine, it will be the A/C drain tube, this will drain condensation from the A/C system which is normal, but if you have engine coolant leaking from this point, you will have a leaking heater core problem.
Apr 12, 2016 at 7:32 AM
