coolant leak
1998 SATURN SC1
180,000 MILES • 4 CYL • 2WD • MANUAL
TREY HRBEK
Coolant leaking from somewhere on the back of block above starter. Replaced intake manifold gasket and still leaking. possible freeze plug? or a crack in block? no water in oil but it is a big leak.
Oct 20, 2017 at 3:37 PM
  • 31,937 POSTS
You may need to get the car up on a hoist to find this leak. a cooling system pressure test and an inspection from under the car may locate this problem. a torch and a flexi head mirror are great tools for locating hard to see leaks as well. flexi head mirrors are cheap and a great addition to your tool kit.
Oct 21, 2017 at 10:36 PM
  • 55,423 POSTS
This guide can help as well
https://www.2carpros.com/articles/car-is-leaking-coolant
Cheers, Ken
Nov 1, 2017 at 12:40 PM
