Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine Cooling
Leak
Coolant leak
1994 FORD EXPLORER
160,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
NWH1962
MEMBER
1 POST
Unknown coolant leak. Nothing showing.
Nov 2, 2019 at 6:23 PM
SCGRANTURISMO
Experienced Mechanic
The best way to find a coolant leak in a vehicle's cooling system is to do a pressure test. It should be readily apparent where the leak is when you do this. Here is a link below explaining how to do a cooling system pressure test:
https://www.2carpros.com/articles/radiator-pressure-test
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Nov 3, 2019 at 12:19 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
