Coolant leak
110,000 MILES • 5.5L • V8 • 2WD • AUTOMATIC
MARIA PE
For two weeks, instrument cluster says top up coolant level. See manual. It tops out with 3/4 gallon. Last night after fifteen minutes of driving on freeway, smoke issued from under hood, and on opening it at home, I saw water pouring from upper hose, like a faucet.
Oct 26, 2018 at 12:24 AM
  • 110,248 POSTS
If the leak was the hose itself, it will need replaced. Here is a link that discusses how to find a leak as well as how one is repaired. If you page down a bit, it comes to the radiator hose.
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/replace-radiator-hoses
Let me know if you have other questions or need help.
Oct 26, 2018 at 11:39 AM
