Coolant leak
200 MILES
ANGELA BEAR CROWELL
Got a new water pump a couple days ago. yesterday it said low coolant we put it in, and it came right back out. wondering if they even put a new one on?
Mar 13, 2022 at 12:29 PM
  • 110,248 POSTS
Angela,
Can you tell approximately where the leak is coming from? A water pump can leak, but it usually doesn't come out that fast. It has to leak through a weep hole that is small. Based on your description, it sounds like a hose has come off.
Let me know what you see when adding coolant. Also, take a look through this link. You may find it helpful.
https://www.2carpros.com/articles/car-is-leaking-coolant
I will watch for your reply.
Mar 13, 2022 at 12:41 PM
