Coolant leak
150,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
BLAH760
I filled the radiator with coolant and about a week later I notice liquid all over my garage and the coolant was really low. I don't know what the issue could be I'm not much of a car guy.
Apr 9, 2019 at 9:35 AM
SCGRANTURISMO
  • 4,897 POSTS
The best way to check for a coolant leak is to visually inspect your vehicle's engine. Check the bottom of your radiator (petcock), upper and lower radiator hoses, radiator, radiator fill cap, expansion tank and expansion tank hose, water pump (underneath weep hole), and the intake and outlet heater hoses. It should be readily apparent where the leak is. It will be wet or have a washed spot there. If you can't tell by visual inspection then a pressure test should expose where the leak is. I have included a few links below for you to go to:
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Please go through these guides and tell us what you were able to find out please.
Thanks,
Alex
2CarPros
Apr 9, 2019 at 12:43 PM
