Coolant leak
124,000 MILES • 4.6L • V6 • 4WD • AUTOMATIC
DEBG1963
Left hand side of the water pump/engine housing block level with top of frame rail, 1/8 inch steam that sprays when running, leaks when not.
What is your best diagnosis?
Sep 23, 2018 at 4:56 AM
  • 110,246 POSTS
That could be a few things. First, if I had to take a guess, it sounds like it could be a heater hose. However, you really need to pressurize the system and then you will be able to locate the leak. Here is a link that discusses how to find and repair different types of coolant leaks:
https://www.2carpros.com/articles/car-is-leaking-coolant
See if that helps and let me know. If you find the leak or not and need additional help, let me know.
Sep 23, 2018 at 1:39 PM
