Coolant leak
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
FLOSKIVB
put green coolant in. Drove short distance.
coolant all leaked out under car. Added water. Drove short distance. All leaked out. Added more water. Been driving for several days and none has leaked out. Any ideas of what the problem is? Thank you
Jul 8, 2020 at 4:44 AM
Good afternoon,
It could leak from dozens of places. I would start with a pressure test to find the leak. It is a simple test and you can rent a tester at a parts store.
https://www.2carpros.com/articles/radiator-pressure-test
I would start there and when you find the leak, send some pictures to this post so I can see them and help you get to a resolution.
https://www.2carpros.com/articles/car-is-leaking-coolant
Jul 8, 2020 at 7:44 AM
