Coolant leak
1997 JEEP WRANGLER TJ
125,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
LEON17
After I parked coolant sprayed out everywhere under my hood when I looked it was no longer leaking. The hoses and radiator looked okay, there was still coolant left. I turned on my vehicle to try and find the leak, but when I turned it on again it did not leak. I let it run for fifteen minutes and nothing happened. There is no white smoke coming from the exhaust and the oil looks normal. The radiator cap is also only a month old.
Jun 25, 2018 at 11:42 AM
DANNY L
  • 5,648 POSTS
Hello I am Danny.
I would suggest using a cooling system pressure tester to double check for leaks. It pressurizes the system and any leaks would be noticed.
https://www.2carpros.com/articles/radiator-pressure-test
Jun 25, 2018 at 7:47 PM
