Coolant leak
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEVINM01
  • 63 POSTS
So I have had a coolant leak for some time now. I am having to regularly fill up with coolant at least weekly or every two weeks. I was told by an Mercerizes Benz specialist that I have leak coming from my oil cooler to cylinder head plastic water pipe which appears to be cracked. They gave an exorbitant quote for the repair, so I am asking, what is actually involved in replacing this part?
(https://www.ecstuning.com/b-genuine-mercedes-benz-parts/coolant-pipe/2712001352/ )
Is this something I can do on my own, or should I refer to a specialist? My skill level is not particularly advanced. I have replaced the starter, and other more minor repairs. I generally do no like to mess with the actual Mercerizes Benz engine.
Feb 9, 2018 at 6:07 PM
  • 55,721 POSTS
Hey Kevin,
I think this is located at the rear of the engine can you take a picture of where it is located so I can help you? I used to have one of these cars but cannot remember where this piece is.
Cheers, Ken
Feb 12, 2018 at 2:39 AM
KEVINM01
  • 63 POSTS
Ken,
The part is in the most inconvenient place possible. I've tried to photograph it, you can't see anything in the photo.
Your best bet would be if you had access to a C230 model would be to look at it and try to find it to even see what I'm talking about. I mean I'm sure you looked at the part on an engine diagram https://www.mbpartsworld.com/auto-parts/2003/mercedes-benz/c230/kompressor-trim/1-8l-l4-gas-engine/cooling-system-cat That's pretty much the best I can do as far as getting you an image.
Feb 15, 2018 at 4:07 AM
KEVINM01
  • 63 POSTS
I mean location-wise its in between the back of the engine and firewall. And it's such a tight space. You can't even access it with a tool. But I don't know how the repair is performed
Feb 15, 2018 at 4:09 AM
KEVINM01
  • 63 POSTS
I think this youtube video might be showing the same part, but I'm not 100 percent sure https://www.youtube.com/watch?v=DV1MF0VbXfk
Feb 15, 2018 at 4:12 AM
  • 55,721 POSTS
Yep that is it, nice video find. That will be tough to change but I think it can be done without removing the cylinder head using small wrenches and 1/4 drive sockets and ratchet. If there is some doubt call the dealer and ask how much the price will reflect the job difficultly.
Feb 15, 2018 at 11:23 AM
KEVINM01
  • 63 POSTS
I mean MB dealer says 3 hrs of labor.
Feb 15, 2018 at 11:18 PM
KEVINM01
  • 63 POSTS
I think some stuff needs to come out to do the job, but I dont know what or how
Feb 15, 2018 at 11:19 PM
KEVINM01
  • 63 POSTS
I may end up taking to a shop or dealer for the repair
  • 55,721 POSTS
3 hrs means it is tough but not enough to remove the cylinder head. So the cost labor is about $350.00.
Let me know what you end up doing.
Feb 17, 2018 at 2:53 AM
