Coolant leak only when engine is running?
126,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ROERIGRAIDER1
Slow coolant leak passenger side under car. Only when running. Could it be the heater hose plastic elbows I read about? No sign of any oil in coolant or white smoke??
Feb 24, 2021 at 8:48 AM
  • 110,248 POSTS
It is very possible that it could be a heater hose. However, remember coolant will travel and may end up somewhere different than where it starts.
Here is what I suggest: We need to determine the source before a repair can be made. So, here is a link that explains how to pressure test a cooling system. You can do this when the engine is cold to locate the problem. Also, you will need a pressure tester. Most parts stores will lend one to you free of charge.
https://www.2carpros.com/articles/radiator-pressure-test
Here is a link that explains in general how to repair a leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
_____________________________
I hope this helps you locate the problem. Once you confirm the problem, let me know what it is and I can further direct you.
Take care and God Bless,
Feb 24, 2021 at 1:01 PM
ROERIGRAIDER1
Thanks.
Feb 25, 2021 at 2:49 AM
  • 110,248 POSTS
You are very welcome. Let me know if you need help or have other questions.
Feb 25, 2021 at 9:58 AM
