Coolant leak coming from the driver side of the engine?
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
I have a coolant leak coming from the driver side of the engine. The first photo is from the top side. The second and third photo I removed the driver side wheel and zoomed in from up under the wheel well. I’m trying to figure out exactly where the leak is coming from. The red mark is where it is dripping down on the engine block. Your thoughts and assessment?
Apr 28, 2025 at 10:59 AM
BEETLEPUNK21
  • 127 POSTS
Possibly it’s coming from here?
Apr 28, 2025 at 11:04 AM
  • 55,782 POSTS
You bet, that was going to be my suggestion. I would remove the thermostat housing assembly to inspect the O ring seal they use to seal the coolant from leaking. Also, check the housing for cracks in the plastic. Please upload images of the failure when you get it apart so we can see the problem ;)
Apr 29, 2025 at 4:54 AM
BEETLEPUNK21
  • 127 POSTS
Are there any special instructions when installing the thermostat and housing? I bought the thermostat and housing and installed it, and it is leaking worse than what the previous one was.
May 2, 2025 at 9:03 AM
  • 55,782 POSTS
Just a torque specs, did you clean the gasket surface, also did you see where the old gasket/housing failed?
Here is a guide that may able to help:
https://www.2carpros.com/articles/car-is-leaking-coolant
Check out the images (below). Let us know how it goes.
May 3, 2025 at 4:21 AM
BEETLEPUNK21
  • 127 POSTS
The picture you sent was for a six cylinder. Mine is a four-cylinder. I took a chance and put blue RTV sealant on all three of the inlet/outlets of the new thermostat housing. It was one I bought from Amazon. I just now ran the engine for a good 30 minutes and no leaks!
May 4, 2025 at 10:09 AM
  • 55,782 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
May 5, 2025 at 3:07 AM
BEETLEPUNK21
  • 127 POSTS
Thank you car pro’s for your help!. I am so grateful to have found this website!
May 5, 2025 at 3:47 AM
