Coolant leak
210,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JORDANNGIAU
  • 34 POSTS
There has been a bit of coolant leaking onto the exhaust bracket as seen on the picture. It seems that it's also wet around the area in the picture as shown. not too sure what connector this is which is below the intake manifold. There also seems to not be a leak from the heater hose from the firewall which is a common leaking place.
Dec 4, 2020 at 12:22 AM
Good evening,
The first thing I would do is to pressure test the system and look for the leak.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
You can rent a tester at a parts store for this procedure. Once you determine the leak, get back to me so I can help you more.
https://www.2carpros.com/articles/car-is-leaking-coolant
Jan 28, 2021 at 1:36 AM
JORDANNGIAU
  • 34 POSTS
Okay, not too sure if they do renting of special tools in Australia unfortunately...
You can get a cheap tester at a parts store.
