Coolant leak
100,009 MILES • 4.3L • 6 CYL
PKMOORE71
Coolant leaking from behind a.c. compressor just to right of fuel pump
Nov 15, 2018 at 6:52 AM
Good morning.
The fuel pump is in the fuel tank.
Have you pressure tested the system to pin point the exact area?
The intake manifold is the first thing that comes to mind but needs to be confirmed before assuming anything.
Can you post a picture of what you see?
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Oct 3, 2020 at 4:14 AM
