Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Engine Cooling
Leak
Coolant leak
2002 CHEVROLET S-10
100,009 MILES • 4.3L • 6 CYL
PKMOORE71
MEMBER
1 POST
Coolant leaking from behind a.c. compressor just to right of fuel pump
Nov 15, 2018 at 6:52 AM
Experienced Mechanic
Good morning.
The fuel pump is in the fuel tank.
Have you pressure tested the system to pin point the exact area?
The intake manifold is the first thing that comes to mind but needs to be confirmed before assuming anything.
Can you post a picture of what you see?
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Oct 3, 2020 at 4:14 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
