Coolant leak under harmonic balancer?
120,000 MILES • 4.0L • AUTOMATIC
BRYON CHASE
Coolant dripping right under harmonic balancing pulley. Bad water pump?
Sep 11, 2026 at 4:10 PM
MECHTRIX
  • 601 POSTS
Yep most likely
Sep 11, 2026 at 8:24 PM
MECHTRIX
  • 601 POSTS
But forst look around at all the hoses parting lines where gaskets can leak you might get lucky and find somthing leaking nearby but if not than its most likely the pump giod luck
Sep 11, 2026 at 8:27 PM
