Coolant leak
90,300 MILES • 2.2L • TURBO • AUTOMATIC
UDDINSADI7
coolant is leaking cant find from where. water pump also changed. took it to local garage they cant find anything. but i realise when i turn on interior heater on coolant sign come on the dashboard and i heard a noise and when i stop. i found that from the white plastic coolant system one small pipe came off and coolant was spill from there.
Feb 9, 2021 at 2:25 AM
  • 110,248 POSTS
Have you reinstalled the hose that came off the coolant reservoir? Can you take a pic of the hose in question and upload it for me to see?
Also, for some reason, I'm not showing a C220. Is that the correct model? I see a C250. It may be because you are not in the US. Let me know.
Here is a link you may find helpful as well:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know if that helps or if you have other questions.
Take care and God Bless,
Feb 9, 2021 at 9:39 AM
