Thermostat replacement?
1998 CHEVROLET S-10
260,000 MILES
CHIPDEALER
Coolant seems to be coming from behind plate behind fan clutch. Is there a gasket behind there? It is a 2.2. The water pump is to the right of the fan.
Jan 30, 2016 at 9:19 AM
WRENCHTECH
  • 20,761 POSTS
Possibly the thermostat but you need to have it pressure tested and follow the leak to it's source. https://www.2carpros.com/images/external/78450663.jpg.gif
Oct 3, 2020 at 4:43 AM
CHIPDEALER
The thermostat housing is dry. I will pressure test it tomorrow, my tester is at work, when the motor is running the coolant is running down from above the fan pulley.
CHIPDEALER
I see now where it is probably leaking. I didn't know there was a gasket where the thermostat housing bolts to front of motor.
THIS IS MIKE
  • 686 POSTS
CHIPDEALER
Feb, 6, 2016 AT 10:15 AM
Can you send me the picture of where the throttle cable bracket goes. I have had it apart too long to remember.
