Coolant is returning to reserve
106,100 MILES • 4 CYL • 4WD • AUTOMATIC
OMOTOSOKT
Coolant is returning back to reserve.
Jan 3, 2021 at 8:15 PM
Normally this is due to a restriction in the cooling system but we need to start with looking for leaks, and excess pressure.
So let's pressurize the system and see if it holds pressure. Here is a guide that will help with this:
https://www.2carpros.com/articles/radiator-pressure-test
If it does then we need to test for a blown head gasket. Here is a guide that will help with this as well:
We don't have a manual on this vehicle but this issue should be general enough that we can assist with this info and not need your vehicle specifics.
Let us know what happens with this and we can go from there. Thanks
Jan 5, 2021 at 9:26 AM
