Coolant in oil
2016 CHEVROLET SILVERADO
35,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
GARY COLE2
Coolant was accidentally put in the oil. I have drained as much as the oil as I can. How can make sure I got all the coolant out?
Sep 10, 2018 at 12:51 PM
Good morning.
Oil will settle to the bottom of the pan if left overnight.
Let it sit overnight and then drain the oil again. If there is any coolant left it will come out first before the oil.
Run the engine for about 500 miles and then change it again.
Then you should be good.
Sep 10, 2018 at 8:04 PM
