coolant in oil
107,000 MILES • 2.0L • 6 CYL • FWD • MANUAL
RYAN MURPHY
i poured a shot glass worth of coolant when topping up my oil. How bad will it be if i drove down to a garage or do not even have to worry?
Aug 8, 2017 at 6:27 AM
CARADIODOC
  • 34,413 POSTS
That is not a lot of coolant, but you will want to have the oil changed soon. Antifreeze melts the soft first layer of metal on the engine bearings. Those bearings are thin curved strips of metal that have very highly-polished rotating parts on them. They have a clearance of around .005" that is filled with pressurized oil. When the metal starts to come apart, the flakes chew up those polished parts, and that further destroys the bearings. That can cause a major failure within minutes. You want to get that antifreeze out of there as soon as possible. Be aware too that during an oil change, there is about two quarts of oil that does not drain out. It is stuck in the oil pump and passages. That means there will still be a little antifreeze left in there after one oil change. The amount you described is rather small, so I would be comfortable that just one oil change will get most of the antifreeze out.
Aug 8, 2017 at 9:25 PM
