Coolant in engine oil, but engine has not been overheating
219,000 MILES • 4 CYL • 4WD • AUTOMATIC
SG183
About 3 days ago, I was checking my oil level, was about to make the drive an hour away up to a ski resort.
I noticed that there was this, almost milky, creamy, light brown colored gunk where i put my dipstick.
I thought, okay, I will take it in to get an oil change, whatever.
I changed the thermostat the day before the oil change.
But when i took it in the mechanic refused to work on it and said that this could indicate a blown gasket.
I had no idea.. my thermostat may have been broken, so i didn't notice any overheating.
Feb 8, 2020 at 6:21 AM
Just because it is not overheating doesn't mean it is not a head gasket issue. Unfortunately these signs do point to a head gasket issue and not anything to do with the thermostat. That may just be a coincidence.
Here are some guides on how to determine if this is the issue:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Run through this info and let me know what you find and we can go from there. Thanks
Feb 8, 2020 at 6:49 AM
Good evening,
Just to add to the question, GM had issues with the 2.5. The back bolt on the cylinder head on the driver's side is a stud. They had issues with that bolt stretching and the head gasket leaks coolant into number 4 cylinder.
The remedy was to remove the head, replace the gasket and to replace the bolt with an updated bolt.
Feb 8, 2020 at 7:11 AM
