Coolant hose snapped
95,000 MILES • 0.5L • 2WD • MANUAL
NELLY104
The hose taking coolant to the engine has snapped. Can I do a temporary fix with some tape if so how long will that last?
Nov 24, 2018 at 4:44 AM
  • 110,248 POSTS
Using tape will not work to repair a broken or torn hose. The system is pressurized when the engine heats up, and tape is not strong enough. You should really just replace the hose. It will be cheaper in the long run because otherwise, you will be adding coolant all the time.
Here is a link that shows how to replace one:
https://www.2carpros.com/articles/replace-radiator-hoses
Nov 24, 2018 at 10:02 AM
