Coolant hose leak replacement issue?
2015 KIA K900
111,000 MILES
BROOKSTYLE28
I recently had a small leak in one of the hoses that is leading to the engine and radiator. The hose had a split as if the thread was thin and it exploded too wide, but split was very small, so the indicator light never came on, we just saw some smoke and decided to pull over. My husband saw the leak and decided to change the hose, now that we have replaced the hose the indicator light is coming on as soon as you crank up as if the car is hot and flashy.
Aug 5, 2022 at 2:14 AM
  • 110,240 POSTS
First, the K900 isn't offered in the US, but I will try my best to help.
Was the coolant refilled and bled to eliminate air in the system? Also, does this happen when the engine is cold?
Aug 5, 2022 at 12:10 PM
