What is the best way to completely flush the radiator and whole system?
85,000 MILES • 4.6L • V8 • 2WD • MANUAL
CMREES13
I have the car listed above SVT Cobra and I am replacing a faulty hose. While I’m at it, I’m also flushing the cooling system with Prestone cooling system cleaner and distilled water. My question is, what is the best way to completely flush the radiator and entire system of past coolant and water so I can be sure I’m not over-diluting the system?
Aug 13, 2022 at 2:59 AM
  • 55,732 POSTS
The best way to flush the system is to drain the system and remove the thermostat, then refill the system with water and the flush chemical and drive it for a day. Then drain the system again including the block plugs (these can be difficult to remove). What I like to do is refill the system with water drive it for a day then flush it out again and keep doing this until you are happy with the clarity, then drain the system one more time and refill with straight coolant. There will be enough water in the block to give you the correct dilution.
This guide can help:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Aug 13, 2022 at 4:05 AM
