Coolant flowed up from the radiator
2010 NISSAN X-TRAIL
13,000 MILES
PORTGAS D ACE
  • 28 POSTS
I have a question. when i starting the engine the coolant flowed up from the radiator. Does this mean that l have a problem in the engine and cylinders?
Feb 13, 2020 at 6:01 AM
  • 110,240 POSTS
If it is shooting out of the radiator when you start it, there is a chance you have a bad head gasket. If compressed air is getting into the system, it can cause this.
Here is a link I need you to look through. It explains what to look for with a bad head gasket. Check it.
_________________________________
Let me know what you find and what size engine you have. If we determine it to be a head gasket, I can explain how to fix it.
Feb 13, 2020 at 9:52 AM
PORTGAS D ACE
  • 28 POSTS
I replaced the gasket and I marked facing for cylinder head 1 month ago.
Feb 14, 2020 at 4:05 AM
  • 110,240 POSTS
Does the coolant shoot out of the radiator if the engine is cold, coolant full, and engine started?
Feb 14, 2020 at 6:34 AM
PORTGAS D ACE
  • 28 POSTS
Yes, it shot out when the engine was cold.
Feb 15, 2020 at 3:30 AM
  • 110,240 POSTS
You have a bad head gasket. Compressed air is getting into the cooling system and causing that to happen.
Just to confirm, go through the aforementioned link that explains how to check for a bad head gasket. Also, let me know what size engine is in the vehicle. This model isn't offered in the US, but I will try to get info for you.
Let me know what you find.
Feb 15, 2020 at 11:08 AM
PORTGAS D ACE
  • 28 POSTS
The engine size is 2.5L ..can you explain what mechanical problem I have ???
Feb 15, 2020 at 2:05 PM
  • 110,240 POSTS
What can happen is the head gasket can be damaged and allowing compressed air to enter the cooling system. Are there air bubbles in the coolant when you turn the engine off?
Feb 16, 2020 at 8:45 AM
PORTGAS D ACE
  • 28 POSTS
No there wasn't any air bubbles in the coolant when the engine turn off.. but the coolant was rising up when the engine was working.. did you mean that the new head gasket is not suitable for the engine because I changed the head gasket 1 month ago?
Feb 18, 2020 at 6:59 AM
  • 110,240 POSTS
The gasket should be fine, but there could be other issues which can still cause a leak such as a warped cylinder head, improper cylinder head torque and so on. It isn't uncommon for the coolant to move in the radiator. however, I thought you mentioned it sprayed out when cold. That is indicative to a leak between the cylinder head and the cooling system. However, if there are no air bubbles, chances are that isn't the issue.
When you have the system closed, are there any issues with overheating or leaks?
Feb 18, 2020 at 11:46 AM
PORTGAS D ACE
  • 28 POSTS
No, I haven't issues with overheating but there is leaking of coolant under the engine but I think it's from freeze plug.
Feb 18, 2020 at 1:20 PM
  • 110,240 POSTS
That is a problem. Have you tried to pressure test the system? Here are directions for doing it. Also, you will need a pressure tester, but most parts stores will lend or rent one to you.
https://www.2carpros.com/articles/radiator-pressure-test
Do that and let me know where you find the leak.
Feb 19, 2020 at 12:35 PM
