Coolant fans are coming on (high speed) at idle (parked) and when you come to a stop while driving. They come on randomly at high speed. When driving they will go off, only come on randomly when stopping or parked at idle.
I looked at the high pressure A/C switch thinking it might be opening (NC open on high pressure) randomly when fan came on at idle. Disconnected switch when fans came on at Idle and fans remained on at high speed. Then they would turn off after a few minutes at idle. Could the ECT be randomly failing sending a signal to the ECM to turn fans on? The fans run normal while driving and there is no heating or cooling problem. I thought if I was getting poor heat transfer through cooler the fans would stay on all the time, not randomly coming on and off at high speed?
I am still troubleshooting, next I am going to take temperature readings when the fans come on at idle.
I have never seen where fans come on at high speed randomly at engine idle. ECT is the only other player in this picture unless I am missing something?
Any help or guidance would greatly be appreciated.
Thanks,
Thanks,
Sep 4, 2020 at 2:49 AM
