I am planning to replace the water pump. I am wondering at what temperature of the coolant should my cooling fan comes on?
Aug 30, 2024 at 10:27 AM
✓Experienced Mechanic
The engine cooling fan should turn on at approximately 200°F. +/- 5°F. I attached a picture below indicating that temperature. Note that it indicates above 199°.
Let me know if this helps or if you have any questions about the water pump replacement. Here is a link that explains in general how it is done. If you need specifics, let me know.
I checked it yesterday. in my car the fan comes on when the temperature is at 205. is it okay?
Aug 30, 2024 at 10:29 PM
Yes, that is perfect as far as I'm concerned. The actual thermostat in the cooling system doesn't fully open until the coolant temperature reaches 195°F. So, 205°F makes sense to me.
Aug 31, 2024 at 11:27 AM
YAZIDAN
MEMBER
just let you know water pump and thermostat done. thank you
Aug 31, 2024 at 12:21 PM
No problem whatsoever. Take care of yourself and feel free to come back anytime in the future.
