Coolant fan not operating automatically
1994 SATURN SC2
90,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
EDDOTSON
Coolant fan is not operating automatically. It has a new temperature sending unit.
Dec 20, 2017 at 12:26 PM
CARADIODOC
  • 34,367 POSTS
Unplug the two-wire coolant temperature sensor while the ignition switch is on. The engine computer should turn the radiator fan on by default. If it does, the system is working. A lot of GM engines have to get uncommonly hot before the fan turns on, possibly as high as 226 degrees.
Dec 21, 2017 at 8:58 AM
