This is a pretty simply cooling fan circuit, as cooling fan circuits go. Unplugging your vehicle's Engine Coolant Temperature sensor (ECT) asnd causing the fans to come on momentarily shows that the Power-train Control Module is working as it should. I would recommend that you replace the ECT and check the three relays that control your engines cooling fans. They are located in the under hood junction block on the left side of the engine compartment. I have included a link below for you to go to:
In the diagrams down below I have also included a cooling fan circuit wiring diagram as well a a Under hood Junction Block diagram and callout for you. Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Jun 15, 2019 at 6:19 PM
