Losing coolant?
178,000 MILES • 6.0L • V8 • TURBO • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
I just bought this truck. It has a lot of aftermarket parts. I believe it’s been “bulletproofed”. Symptoms are that it is losing coolant. No visible leaking coolant. No white smoke. No check engine light. Hoping and praying it’s not a head gasket issue.
Jan 26, 2023 at 4:06 AM
  • 110,248 POSTS
If there are no visible leaks, have you checked the engine oil to make sure it isn't making its way into there?
Do me a favor. Take a look through this link first. It explains the different symptoms of a failing head gasket.
Next, if that is not helpful, then I suggest pressure testing the cooling system. This allows you to slowly and carefully check for leaks while the engine is cold. You will need a pressure tester, but most parts stores will lend one to you.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/radiator-pressure-test
A couple of things to check in addition are these. Make sure the carpet on the passenger side interior isn't wet indicating the heater core is leaking. Also, test or replace the radiator cap. A cap that won't hold pressure will allow the coolant to have a lower boiling point and evaporate.
joe
Jan 26, 2023 at 7:21 AM
BEETLEPUNK21
  • 127 POSTS
Joe,
A new radiator cap seems to have fixed the issue! Thank you!
Jan 29, 2023 at 10:49 PM
  • 110,248 POSTS
Thanks for the update. I'm glad it was something simple and you found it.
Take care of yourself and feel free to come back anytime in the future. You are always welcome here.
Jan 30, 2023 at 10:20 AM
BEETLEPUNK21
  • 127 POSTS
I know, right?! What a relief!
Thank you so much for your help and professionalism.
This platform is such a blessing.
Jan 30, 2023 at 10:54 AM
