Coolant boiling after changing water pump?
200,000 MILES • 3.5L • AUTOMATIC
CHRYSLER 01
  • 157 POSTS
coolant is boiling after changing the water pump .. coolant is boiling when i try to bleed air out the system
... fan works t-stat is a few month old
Jun 6, 2026 at 9:02 AM
CHRYSLER 01
  • 157 POSTS
I have a spill-free funnel
Jun 6, 2026 at 9:04 AM
CHRYSLER 01
  • 157 POSTS
i install new coolant temp sensor
Jun 6, 2026 at 10:00 AM
  • 55,709 POSTS
Yep, that might be a bummer, let drain a small amount of coolant out of the system and do a head gasket test to see if there are leaks. You can have a blown head gasket without coolant in the engine oil fyi.
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle/
and
https://www.youtube.com/watch?v=5zpNjYmmiYY
Please go over this guide and get back to me. Let me know how it goes.
Jun 6, 2026 at 4:25 PM
CHRYSLER 01
  • 157 POSTS
I don't have the equipment to do that
Jun 6, 2026 at 4:50 PM
  • 55,709 POSTS
You can rent it for free from the auto part store.
Jun 6, 2026 at 7:14 PM
CHRYSLER 01
  • 157 POSTS
I don't think it's that , cause It doe not overheat has soon has u start.
Jun 6, 2026 at 9:07 PM
  • 55,709 POSTS
It wont over heat as soon as you start it. A blown head gasket while take a while before it overheats. You may have a defective thermostat as well. Does the engine make a thumping noise when it is overheating, also is the cooling fan on?
Jun 8, 2026 at 8:06 AM
