Coolant bleeder valve
250,350 MILES • 2.4L • 4 CYL • AUTOMATIC
IJOSEPHARCE
Is there a coolant bleeder valve on car if so where is it located?
May 2, 2017 at 8:30 AM
CARADIODOC
  • 34,414 POSTS
Bleeder valves will be on the thermostat housing or near where the upper radiator hose attaches. If there is none, you can remove a coolant temperature sensor instead. Older Chrysler four cylinder engines like the 2.2L and 2.5L also had threaded plugs that could be removed for bleeding. Those were right next to the thermostat and upper hose.
May 2, 2017 at 9:21 AM
