Coolant
136,030 MILES • V6 • 2WD • AUTOMATIC
THINTHIN
I only put Mopar coolant in my van and I heard that it is not correct for my van. Can I still use it?
I also heard that gold colored coolants are better that green colored ones.
I think my van's manual specifies Mopar.
Jun 11, 2017 at 10:37 AM
  • 31,937 POSTS
the coolant specified is MOPAR HOAT if you are using this there will be no problem. if other coolants have been added the system should be flushed and re filled with the correct type. coolants can not be mixed as often they are not compatible with each other.
Jun 11, 2017 at 10:12 PM
