Coolant flowing out reservoir overflow tube
2004 OLDSMOBILE ALERO
160,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
CRISSY9845
Coolant is coming out of overflow tube on reservoir.
Jul 10, 2018 at 10:28 AM
  • 110,241 POSTS
If coolant is coming out there, either the system is over full, the engine is overheating, or a blown head gasket can sometimes fill the system with pressure causing this.
If there is a leak, the coolant could get low and cause the engine to over heat. Here is a link describing how to check for a leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
Another cause of overheating is a bad thermostat. Take a look at these links:
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Next, if radiator cooling fans are not operating, this too can allow the vehicle to overheat, especially in stop and go traffic:
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Check these things first and let me know what you find. At that point, I will be better able to help.
Jul 10, 2018 at 1:14 PM
