Coolant
145,829 MILES • 2.7L • V6 • 2WD • AUTOMATIC
LEXIE DAVIS
I’ve noticed my car cannot hold much antifreeze for a while now. Every time I refill it, it can only hold like 1/4-1/2 of what it should and if it fill it too much then it spits it out the radiator cap.
Jun 16, 2019 at 11:59 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you say it's coming out from the radiator cap then it sounds like it may be a defective cap.Radiator caps have a specific p.s.i. rating and do fail like any other part. Cooling system pressure testers that are used to pressurize/test cooling systems do come with an adapter to test the cap. Here is a tutorial for you to view that shows what is involved:
https://www.2carpros.com/articles/radiator-pressure-test
Most local auto parts stores have a tool loaner program and can rent you a pressure tester.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 17, 2019 at 6:48 AM
